Front tire questions
/ Front tire questions #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all,
There must be some experts on here. I have 20HP Yanmar, dry weight about 1500lbs+500lbs for the loader +the loader will pick up ~1000lbs max. I want to put turfs on the front, the rims that I have available are 14"x5" or 14"x6". The turfs I'm looking at are the diamond tread 6-14 (require 5" rim) and have a capacity of only 660lbs or 25-8.5x14 turfs which require a 7" rim, capacity ~1250lbs.
is 660 enough? can I put a tire that requires a 7" rim on a 6" rim safely, I know I can do it with a car tire, but was wondering about the load.
Please help?
Thanks,
Rob
Hi all,
Please help?
Thanks,
Rob
/ Front tire questions #3
Technically no. Theoretically yes.
/ Front tire questions #4
/ Front tire questions #5
won't two 660 lbs tires give you 1320lbs. I have seen 6x14 turfs on Fitestones site as well as titan's. If you are running a sxs you will also neede to change the rears to match.
/ Front tire questions #6
I've switched the rears already, I've measure the RCI to get matching fronts. While I agree that 660x2 gives 1320, I'm concerned about the odd situation that this might have a failure, on a hill, load in loader shifted,.....
4wd.
That is the reason I am looking for specific rims and tires for the front. I need to match the rolling circumference and front to rear ratio with my originial AG tires.
4wd.
3 Brake Drums (A62613)
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
2014 Nissan Sentra Sedan (A61574)
2014 Nissan Sentra...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
2025 Kivel Quick Hitch Skid Steer Attachment (A61572)
2025 Kivel Quick...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
