Front tire questions
   / Front tire questions #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all,
There must be some experts on here. I have 20HP Yanmar, dry weight about 1500lbs+500lbs for the loader +the loader will pick up ~1000lbs max. I want to put turfs on the front, the rims that I have available are 14"x5" or 14"x6". The turfs I'm looking at are the diamond tread 6-14 (require 5" rim) and have a capacity of only 660lbs or 25-8.5x14 turfs which require a 7" rim, capacity ~1250lbs.
is 660 enough? can I put a tire that requires a 7" rim on a 6" rim safely, I know I can do it with a car tire, but was wondering about the load.
Please help?
Thanks,
Rob
Hi all,
Please help?
Thanks,
Rob
   / Front tire questions #3
Technically no. Theoretically yes.
   / Front tire questions #4
   / Front tire questions #5
won't two 660 lbs tires give you 1320lbs. I have seen 6x14 turfs on Fitestones site as well as titan's. If you are running a sxs you will also neede to change the rears to match.
   / Front tire questions #6
I've switched the rears already, I've measure the RCI to get matching fronts. While I agree that 660x2 gives 1320, I'm concerned about the odd situation that this might have a failure, on a hill, load in loader shifted,.....
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
