front quick hitch ice?
/ front quick hitch ice? #1
megotatractor
New Richland, Minnesota
JD 2210
While we have had near record snow this winter I continue to wish for a snowblower for my 2210. And while I scour the internet for a great price on used equipment a thought occured to me today. AFter clearing away 10" of snow in 10 degree weather I chipped away a lot of ice buildup on the front of the tractor and underneath the bucket cylinders where the cylinder could have gotten bent with just a little more ice. Question is about ice buildup on the front hydraulic quick hitches, is it ever a problem?
/ front quick hitch ice? #2
Yes, it is a problem-no real good way around it.
/ front quick hitch ice? #3
While plow our heavy december snow, an ice block built up in the quick hitch and busted one of the hydraulic fittings coming out of the angle cylinder. I now check for ice often.
/ front quick hitch ice? #4
I'm thinkning it might be worth the extra time/trouble to park the unit in a heated garage until the snow melts off. In my case, the normal tractor storage area is an unheated shed.
/ front quick hitch ice? #5
For about $130 (I think) you can get a kerosene heater from TSC. Put it in your unheated shed and let it run about an hour or two after clearing snow. Just be sure it is not touching anything directly. Works for me to get the snow off the blower when I'm done and comes in handy when I'm in the garage working.
Turns the garage into a nice man cave for me.
/ front quick hitch ice? #7
not sure what RFM is but there you go, use a rear 3 point snowblower and just turn the operator's station around! LOL
/ front quick hitch ice? #9
I clean it off after every use and never worry about it. And its always outside.
/ front quick hitch ice? #10
In 10 deg weather, how does it melt in the first place? Seems at some point the hitch must have been warm, and then parked in the cold.
A pic of the problem might help.
/ front quick hitch ice? #11
The hydraulics give off enough heat to melt show that comes in contact with the hydraulic cylinder.
/ front quick hitch ice? #12
Okay. I've a Deere 4300, and have never experienced ice buildup on the rams. Seems putting the rams through full extension and retraction just before shutting down the engine would purge any collection of slush that might turn to ice in storage. Just a thought. :)
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
Hog Feeder (A66408)
Hog Feeder (A66408)
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
18ft Bumper Pull Trailer (A65640)
18ft Bumper Pull...
2022 EZ-GO ELITE...
