Snowblower Front Mounted snowblower
/ Front Mounted snowblower #1
KevinMcD
Jay, NY (Adirondacks)
Kioti CK30 HST
I am looking into buying a snowblower for my Kioti 30HP tractor. I haved searched the forums and there is alot of info on rear PTO blowers but not much on front mounted blowers. I have about 1500' of driveway I will be cleaning and think doing it in reverse will be a tough job. My questions are.... how are the front mount vs the rear PTO type, will a 30HP tractor with a 12GPM pump handle a front mounted unit and has anyone had any experience with the front mounted type? Thanks in advance.
Kevin McD.
/ Front Mounted snowblower #2
Kevin: I am sure that your tractor can handle a front mounted, but they are a good deal more expensive. Plus, with a front mounted. you can't keep your FEL on in the winter for moving the tops of any piles that are too high for the blower.
I have a B7800 (also 30hp) :and recently bought a Pronovost Puma rear mounted blower for it. In the snowstorm that we had two weeks ago, I did ten driveways. While not quite the equivilent of your 1500', I didn't find having the blower in the rear much of a hassle. I just sit sort of turned half way round, so that I can see what's going on and raise or lower the blower as needed for grade changes. I know that some people here consider the rear mounted uncomfortable, but I didn't find it so.
Hope this helps.
/ Front Mounted snowblower #4
Erskine makes a commercial quality front mount snowblower that is driven off the rear PTO. The FM-601 model would be perfect for your machine. I'm told any dealer can order from Erskine for you. www.erskineattachments.com
Thanks for the input. I went to Erskine website and liked what I saw. I will contact them after the holidays. I know that I am giving up the FEL with the front mounted blower but I think my driveway is going to be a pain to clear in reverse. I'll have to compare prices and maybe I can find someone with the rear mounted blower that I can try out. Here are a couple of pics to give you an idea of what I'll be clearing.
/ Front Mounted snowblower #6
Kevin- If you go to the "Projects" postings area, you'll see a pic of an Erskine snowblower attached to my JD4500 tractor. I believe it is headlined "JD4500 with Erskine Snowblower". It'll give you an idea what it looks like. I have had this blower for approx. 8 years and I have probably put $100.00 in it regarding replacememnt parts. One of the teflon shields inside the blowershoot needed replacing and I once had to replace the chain that operates the auger. Other than oiling and greasing per directions nothing else needs to be done.
/ Front Mounted snowblower #7
That is certainly a healthy stretch of driveway. Also, what it appears that you don't have to deal with (but I do) is a cul-de-sac at the end where the town plow piles everything up. After a major storm, the pile of snowplow-compacted snow at the end of my road (and frequently right in front of our driveway) can be 4-8' high.
Although I have sufficient power to just drill into it with the blower I think that damage to the chute would result eventually, so I remove (or push back) everything above about 2 1/2' that has already been compacted, with the FEL before usng the blower on what remains and on everything that has not been compacted.
Since I frequently need to use the FEL, a front-mounted blower wouldn't work for me. Come to think of it, maybe I am just rationalizing not minding backing up. /forums/images/graemlins/wink.gif
/ Front Mounted snowblower #8
Kevin; If you're looking at Erskine, take a close look at that website: That rear mount is a rear PULL type! Works going forward rather than 'pain-in-the-neck' style. That may be the option you (and I next winter after I build) need.
Dick Thomas
(Colo Mountain bound)
/ Front Mounted snowblower #9
Like others have mentioned backing up doesn't bother me either and I do 700 ft. plus a parking area.I would never give up my FEL. and a good reason is ,we just got a snow storm, than rain ,than freezing rain on top of all that , that a blower could never touch.I would have been up the creek without a paddle if I had come home and faced that mess with a front mounted blower. My fel never comes off my tractor.Good Luck with whatever you choose as I know many folks love the front mounted blower.
Herb,
/ Front Mounted snowblower #10
</font><font color="blue" class="small">( Kevin; If you're looking at Erskine, take a close look at that website: That rear mount is a rear PULL type! Works going forward rather than 'pain-in-the-neck' style. That may be the option you (and I next winter after I build) need.
Dick Thomas
(Colo Mountain bound) )</font>
That's one heck of a snow blower, isn't it? I don't have enough drive to justify a blower, but if I did...that would be the one.
Even HEC could use that pull behind unit, since the tractor driving over the crappy stuff would break up any ice.
/ Front Mounted snowblower #11
Roy, I have never seen anything like that , looks like quite the rig.I'd give her a try if I had it today as we got about another foot of snow last night.
Herb,
/ Front Mounted snowblower #12
I ran the kubota 2650 front mount unit for years, she would throw snow 50' @ 2500 rpm. I now have a 30 hp kubota with the 2782 front blower. This new design can be used on the front or rear 3pt. This new design, when used up front has a center pin break away, you can remove the blower itself leaving the subframe on the tractor & switch back to the fel fairly quickly.
2019 Harley-Davidson FLHTP Electra Glide Motorcycle (A66738)
2019...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
