Sickle Bar Front mount sickle bar?
/ Front mount sickle bar? #1
dwyleecoyote
Northern Ohio
Ford 1320, Kubota 1140 CPX, Kubota BX2360
I am wondering if such a thing exists: front mounted sickle bar mower, operated by a mid mount PTO... Anyone ever see or hear of anything like this, for any tractor?
/ Front mount sickle bar? #2
The only ones I know of look similar to this although they won't fit a 4 wheel tractor. I'd sure like to have one though.
/ Front mount sickle bar? #3
You can get a hydraulic one and then modify it to fit the loader.
How would you plumb that? 3rd function? Or would that be called a front remote? I guess if I was making a frame anyway I could hook up right at the manifold where I just installed my backhoe connector.
Just thinking that it would make more sense to clear certain areas that way. Cut stuff down before you run over it. I seem to spend more time in reverse with my brush hog, just so I don't put a tractor tire on something I don't want to. I am just thinking, and it's probably more effort then its worth. Just bouncing the idea around.
/ Front mount sickle bar? #7
If you have a skid steer quick adapter on your FEL arms, I don't see why you couldn't rig up an attachment for a sicklebar and run the mower with a hydraulic motor. Sounds like a neat welding/hydraulics project.
Of course, self-propelled swathers (aka windrowers) have used front-mounted sicklebars for decades.
/ Front mount sickle bar? #8
Keep in mind a sickle bar is not a brush hog. They’re made to cut grass.
Anything is possible with enough money and know-how. But, I would guess that someone has tried it before, and there’s a reason you don’t see front mounted brush cutters for tractors. I don’t know what that reason is since you can get them on skid steers. Personally, I don't think a sickle bar on the front would be all that useful.
I don't have much experience with sickle bar mowers. My father had a walk behind, Troybilt I think, and I recall the advertising calling it a "field and brush" mower. I know it wouldn't take down small trees like my old brush hog will, but they did claim some pretty gnarly stuff could be cut with it.
/ Front mount sickle bar? #10
I THINK the Troybuilts were built a bit heavier than standard sickle bar mowers. I could be wrong about that.
That's pretty cool. Not exactly what I was thinking, but probably way more useful. I didn't see anything about cost on there- any idea?
Better yet I could hang that thing on my backhoe and do some real sculpting...
/ Front mount sickle bar? #14
Milkman,
Take one of those with a dead engine & hook it up to a QA for the mid mouth PTO or on the leading edge of the FEL. :2cents:
T-Man. :cool:
/ Front mount sickle bar? #16
Sorry i didnt get back sooner. Just run another hose from one of your output remotes and that will work fine.
/ Front mount sickle bar? #20
Several years ago, I saw a front sickle made out of the header from a NH479 hay mower. That included the rolls. The wobble drive was hydaulically driven from a pto pump. Tractor was a JD 4430 and also run with a 4020.
That's a 9' sickle mower for you. Is that enough? Or, would you prefer to have a 12' 499? These mowers go thru 3/4 to 1" saplings all the time, but, they are not shredders. Its "cut once and its done cutting".
Atspower Mini Excavator (A60352)
Atspower Mini...
72" JCT TILLER (A62613)
72" JCT TILLER...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
1996 Champion 540P (A64126)
1996 Champion 540P...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
