Sickle Bar Front mount sickle bar?
/ Front mount sickle bar? #1
dwyleecoyote
Member
Northern Ohio
Ford 1320, Kubota 1140 CPX, Kubota BX2360
I am wondering if such a thing exists: front mounted sickle bar mower, operated by a mid mount PTO... Anyone ever see or hear of anything like this, for any tractor?
/ Front mount sickle bar? #2
The only ones I know of look similar to this although they won't fit a 4 wheel tractor. I'd sure like to have one though.
/ Front mount sickle bar? #3
You can get a hydraulic one and then modify it to fit the loader.
How would you plumb that? 3rd function? Or would that be called a front remote? I guess if I was making a frame anyway I could hook up right at the manifold where I just installed my backhoe connector.
Just thinking that it would make more sense to clear certain areas that way. Cut stuff down before you run over it. I seem to spend more time in reverse with my brush hog, just so I don't put a tractor tire on something I don't want to. I am just thinking, and it's probably more effort then its worth. Just bouncing the idea around.
/ Front mount sickle bar? #7
If you have a skid steer quick adapter on your FEL arms, I don't see why you couldn't rig up an attachment for a sicklebar and run the mower with a hydraulic motor. Sounds like a neat welding/hydraulics project.
Of course, self-propelled swathers (aka windrowers) have used front-mounted sicklebars for decades.
/ Front mount sickle bar? #8
Keep in mind a sickle bar is not a brush hog. They’re made to cut grass.
Anything is possible with enough money and know-how. But, I would guess that someone has tried it before, and there’s a reason you don’t see front mounted brush cutters for tractors. I don’t know what that reason is since you can get them on skid steers. Personally, I don't think a sickle bar on the front would be all that useful.
I don't have much experience with sickle bar mowers. My father had a walk behind, Troybilt I think, and I recall the advertising calling it a "field and brush" mower. I know it wouldn't take down small trees like my old brush hog will, but they did claim some pretty gnarly stuff could be cut with it.
/ Front mount sickle bar? #10
I THINK the Troybuilts were built a bit heavier than standard sickle bar mowers. I could be wrong about that.
That's pretty cool. Not exactly what I was thinking, but probably way more useful. I didn't see anything about cost on there- any idea?
Better yet I could hang that thing on my backhoe and do some real sculpting...
/ Front mount sickle bar? #14
Milkman,
Take one of those with a dead engine & hook it up to a QA for the mid mouth PTO or on the leading edge of the FEL. :2cents:
T-Man. :cool:
/ Front mount sickle bar? #16
Sorry i didnt get back sooner. Just run another hose from one of your output remotes and that will work fine.
/ Front mount sickle bar? #20
Several years ago, I saw a front sickle made out of the header from a NH479 hay mower. That included the rolls. The wobble drive was hydaulically driven from a pto pump. Tractor was a JD 4430 and also run with a 4020.
That's a 9' sickle mower for you. Is that enough? Or, would you prefer to have a 12' 499? These mowers go thru 3/4 to 1" saplings all the time, but, they are not shredders. Its "cut once and its done cutting".
John Deere 8370R (A64126)
John Deere 8370R...
2022 EZ-GO ELITE...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2018 John Deere 4052M (A64126)
2018 John Deere...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
