Snow Front mount Kioti snow blower
/ Front mount Kioti snow blower
Here is a side view of the subframe with the black pin that holds the front up.
The second pin is just behind the step.
If you cannot see I will try and get better pics.
/ Front mount Kioti snow blower #22
Thanks for Pics K man, that definitely looks like more than a 1 man install. I think I'll stay with the rear mount until my neck can't take it anymore.
Yes it helps to have 2 this way one stays on the tractor and the other connects. Connecting is not that hard, like I mention there is only 2 inches to lift the subframe and line up the pin and can be done easily with a bar or small jack. I lifted it up by myself to put a piece 2x4 under it and I would say it probably weighs 200 lbs. Now the blower weighs about 1000 lbs and no need to lift it. I can use the hydraulics for that. Believe me when this blower is mounted and the ease of operation with the joystick and hydraulic shute still better than a rear one. No neck pains lol
No wonder you were confused. That blower hook up is way different to mine.[/QUOTE
Well that explains lol. I sure would like to see a pic of yours just to see how different it is. How old is your CK 27?
/ Front mount Kioti snow blower #26
Don't feel like the Lone Ranger, the Kubota B-3000 has an undercarriage that the Front mount blower is attached to.... first couple of times it was a real hassle mounting it by myself. But it's well worth effort once it's mounted and up & running. Now it's a piece of cake to put on . :thumbsup:
Get my Drift ! :D
Hi Kioti lovers. Do any of you have a front mounted snowblower on your Kioti CK series. I need to know. Do you find it difficult to attach? I mean do you do it in 2 pieces or one. Last year I took mine off and did it in one whole piece and had a heck of a time taking it off the tractor. I realized after that I should of taken the blower off first then the quick attach. Am I right or did I do it wrong. This year I had the dealer come out and put it on but I was not home when they came and now it is mounted on again Jeez. I wanted to be there to see how they did it lol. Any input on this would help me a lot cause I do things alone. Any suggestions
Gilles
/ Front mount Kioti snow blower #28
Get my Drift ! :D
That picture says it all as far as cab / no cab . Nice pic , like the headset .
/ Front mount Kioti snow blower #29
It's a heavy set up... But with weight comes reliability! It have never failed, but it's on the heavy side. I have a friend who combined in a late fall: oil change - maintenance - chain installation - front mounted snow blower on the same service call. Make sense to me.
/ Front mount Kioti snow blower #30
I do have a front mount blower (KS72-240FM) on my DK40SE HST tractor. The front mount blower, and its heavy front mount hitch with mid mount PTO drive, is the primary reason I bought the tractor. I'm now 72 years old , and had grown tired of plowing snow, or worse yet, using the rear mount 8' snowblower on my John Deere.
I have only removed the front mount assembly once, but had no particular trouble with the process. The mount is heavy, and I removed the thing on the concrete floor in my tractor shed. The manual is a little sketchy on photos, but easy to follow. After the snow blower is off, mount removal is easily accomplished, also by following the manual, which is separate from the blower manual. The remounting procedure is similarly easily followed, and only takes a little while.
A few short pieces of dimensioned hardwood, 2x4, 4x4, etc and a hydraulic pallet jack are handy to have, if you want to move the mount and/or the blower to the back corner of your garage for storage.
The Kioti snowblower is, I believe, made for Kioti by Normand of Canada. Mine has about fifty hours of use this year, about the same last year, and is a very user friendly, functional machine. The DK40's heated cab is very much appreciated. I'll be reminded again soon, as we are just in the start of another blizzard.
/ Front mount Kioti snow blower #31
Mine a pto driven Martin 54" snob lower, a real charm!View attachment 401238
Nice looking setup. What is that behind the driver seat? Is it a carry bin or roll cage?
/ Front mount Kioti snow blower #32
Thanks, it's a carry bin, "chainsaw special, very handy!
/ Front mount Kioti snow blower #33
I agree with putting the front mount on on concrete. I put mine on dollys and keep it in the back to the garage while the convertible is out in the summer.
/ Front mount Kioti snow blower #34
Gilles
When mine was delivered Dec. 4 23 I asked the mechanic how to remove it. He told me to drop the whole thing (blower and sub-frame). He did stress that it should be done on a level surface. Don't forget to disconnect the hydraulics and PTO. He did mention that some dun-age to kinda prop the assembly was necessary. Oh, and when I asked how long it would take he said about 30-40 minutes. I'll find out in a couple of months. Hope this helps.
/ Front mount Kioti snow blower #35
I took my front mount blower off 6 years ago and never put it back on. It takes two to do it easily, but if you want to do it alone, use a floor jack, you know the one with wheels on it. Put it on in two pieces, because it is hella heavy.
/ Front mount Kioti snow blower #36
I've got a CK3510 with the KS66. This is my first year with both, so I can say it has worked well but i have barely used it. However, I have mounted and unmounted it several times. I chose (stupidly) to receive the blower and frame while they were still in the crate. Mediocre instructions and very heavy! But it gave me an intimate look at how it all works.
My buddy helped me and I have done it myself. What I found best was two sets of furniture dollies. Two larger ones for the blower and two smaller ones for the frame.
For the blower, I place the outside edge of the dollies on the edges of the snow blower, just inside the shoes, and then slide the 1x4 on the back of the dollies under the square box portion of the blower unit (just in front of the round support tubes). I do not use the retractable foot. I find this is balanced really well and i can move the unit around with ease.
Then i slide the two smaller dollies under the frame/cradle. Remove the rear shaft, then use one of those smaller jacks to lift the front by the hump, pull the pins and lower onto the dolley. Then, use the jack on the side of the cradle to take the weight off the pins and drop down to the dolly.
Sorry I don't have pics, but there is a guy on youtube with a good demonstration of how to do this with jacks, but he doesn't use dollies so he drives over the frame.
Fearl Bridge Farms
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
New Holland Hayliner 273 Square Baler (A65640)
New Holland...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2022 EZ-GO ELITE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
