front loader problems
/ front loader problems #11
Also, make sure the TPH lever is not in the extreme "up" position
wdchyd, not too familiar with hydraulic acronyms, what does TPH mean? Three point hitch?
/ front loader problems #15
Had this happen to me with my #67 loader but in my case I broke the little spring that was in one of the valves (float) at the lever control. I could lower the bucket by pushing forward but I had hydraulic pressure. In my case the valve within the lever control (called a spool valve and has a bunch of orifices that when lined up with holes in lever housing direct hydraulic flow) could not come back when in neutral detent so my fel would go up by itself. JD does not sell spool valves as valves are lapped for particular housing. Would have cost me $700 for new lever control. Smart parts guy found the spring on a schematic for a garden tractor. $4.38. Worked better than ever.
thanks to all who have given me info and recommendations. Problem has been solved. J.J. had it right. It was just an uncoupled Q.D.
I like it when it's something simple.
/ front loader problems #18
I good method to secure a FEL in the air is cut angle iron to length of exposed cyl rod,insert and then secure angle iron with hose clamps.
Jim I failed to do the last part of your suggestion once and was in for a big suprise. PLING went the angle iron as if flew out.:ashamed:
/ front loader problems #19
k0ua
One can never take """too many safety precautions"""" when working around raised hyd implements.
/ front loader problems #20
Rather than post a new thread I am replying to this if that is OK? I have a JD430 loader just back from the dealer after they removed it for other repairs. The loader works as it should except for when I want to dump the bucket. When trying to dump the bucket the engine and maybe hydraulic pump seems to labor and the bucket drops forward very slow. I have removed and re-attached the QDs at least twice with no results. any ideas? could it be a QD coupling? and if so are the couplings easy to replace?
Thanks in advance for any help.
TexasYankee
Case SV280B (A60462)
AGT Industrial ExRC54 (A60463)
AGT Industrial...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
