front loader problems
/ front loader problems #1
tommyboy1
north branch, michigan
ford 4600
Hello all,
I'm trying to diagnose a hydraulic problem with a John Deere front end loader.
I was using the loader when all of a sudden I was unable to control the bucket or loader arms through the control levers. The front loader raised all the way to the uppermost position and the bucket has no control. I did not see any hydraulic fluid leakage and the control valves seem to move freely when I pull or push the control levers.
After closer inspection, it appears that a piece of brush or sapling may have loosened a hydraulic coupler at the bottom of the tractor but I didn"t see hydraulic fluid leakage around this area. I'm wondering if anyone out there has any suggestions that may lead me to a solution.
thanks,
tommyboy1
/ front loader problems #2
Just re-connect all QD's and try again.
thanks J.J., i'll give it a try. Can hardly wait to get work in the 10 degree weather.
/ front loader problems #4
If the loader is up, you better bleed it down before you unhook anything. JJ must of forgot to say that.
/ front loader problems #5
Was the disconnect from a loader hose or some hose further back?
With the loader up, there will be pressure on the QD, so it might be difficult to connect.
If he did connect with the valve in neutral, the loader should not move very much.
Put a 4 x 4 brace under the loader arms before connecting or slowly bleed the fluid from the cyl.
thanks guys,
I planned on bracing the loader before working on it,although bleeding it down may be a better option, I don't want to have the loader come crashing down if I need to remove or replace the qd. What's the best way to bleed the system down safely? Is there usually some type of valve in the line for this purpose?
J_J, the disconnect is further back on the underside of the tractor but looks like it directly feeds the loader controls. I haven't been able to get to the loader due to snow removal around the house. I will probably start working on it tonight. BRRR a high of 10 degrees in Michigan.
/ front loader problems #7
I would brace the lift arms anyway, and then either tap on the ball or poppet or loosen the QD to release some fluid.
Also wiggle the loader levers to release any pressure.
/ front loader problems #9
I good method to secure a FEL in the air is cut angle iron to length of exposed cyl rod,insert and then secure angle iron with hose clamps.
/ front loader problems #11
Also, make sure the TPH lever is not in the extreme "up" position
wdchyd, not too familiar with hydraulic acronyms, what does TPH mean? Three point hitch?
/ front loader problems #15
Had this happen to me with my #67 loader but in my case I broke the little spring that was in one of the valves (float) at the lever control. I could lower the bucket by pushing forward but I had hydraulic pressure. In my case the valve within the lever control (called a spool valve and has a bunch of orifices that when lined up with holes in lever housing direct hydraulic flow) could not come back when in neutral detent so my fel would go up by itself. JD does not sell spool valves as valves are lapped for particular housing. Would have cost me $700 for new lever control. Smart parts guy found the spring on a schematic for a garden tractor. $4.38. Worked better than ever.
thanks to all who have given me info and recommendations. Problem has been solved. J.J. had it right. It was just an uncoupled Q.D.
I like it when it's something simple.
/ front loader problems #18
Jim I failed to do the last part of your suggestion once and was in for a big suprise. PLING went the angle iron as if flew out.:ashamed:
/ front loader problems #19
k0ua
One can never take """too many safety precautions"""" when working around raised hyd implements.
/ front loader problems #20
Rather than post a new thread I am replying to this if that is OK? I have a JD430 loader just back from the dealer after they removed it for other repairs. The loader works as it should except for when I want to dump the bucket. When trying to dump the bucket the engine and maybe hydraulic pump seems to labor and the bucket drops forward very slow. I have removed and re-attached the QDs at least twice with no results. any ideas? could it be a QD coupling? and if so are the couplings easy to replace?
Thanks in advance for any help.
TexasYankee
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case SV280B (A60462)
2021 INTERNATIONAL CV515 4X2  S/A FLATBED TRUCK (A59906)
2021 INTERNATIONAL...
