front loader and 3 point jerky when raising
/ front loader and 3 point jerky when raising #1
Chuck Boyd
Suffolk,Va.
Ford Compact 1520
i bought this ford compact 1520 with a front end loader last week and the fella told me he had put a new clutch and brakes on it and he didnt mess with the hydrallics,worked good before the repairs and now it has problems lifting both the bucket and the 3 point hitch.i saw where this fella had the same problem back in 2/08 i believe but he never posted the fix. thanx for any help. this is my first tractor.
chuck
/ front loader and 3 point jerky when raising #2
Sounds like low hydraulic fluid to me . I would check that first , with the 3 point & the loader all the way down. Best of luck & welcome . Bob
/ front loader and 3 point jerky when raising #4
My FarmTrac 535 acted like yours for a while before the hydraulics stopped working completely. The intake line to my pump has an external spin-on filter, and upstream of this, there is a permanent mesh filter inside the transmission case. This mesh filter was completely stopped up with stuff like vaseline. When I cleaned it up and re-installed, everything worked like new again. Good luck with yours -- might be a similar situation.
CASE TV380 (A67714)
CASE TV380 (A67714)
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
3146 (A63117)
3146 (A63117)
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
