front hitch/first project
/ front hitch/first project #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
001.jpg001.jpg001.jpg001.jpg001.jpg001.jpg001.jpg001.jpg001.jpg001.jpgThis is my first project I bought an atv reese sleeve that I bought at hf and welded it on backwards to a I beam and bolted it to my tractor the hole that usualy bolts toan atv is forward so I can pull a garden tractor type trailer/or put a ball on it without reese hitch so now I have 260$ in my tractor as I paid 250$ for tractor and 10$ far hitch sleeve.
I accidently posted same pic several times heres some others003.jpg003.jpg003.jpg
/ front hitch/first project #4
Nice job! Looks super heavy duty. You could push down some small trees with this setup.
thanks its not a shiny new tractor but I love it my dad has a kubota but this one is mine and to me its baaaad.
/ front hitch/first project #6
Looks good! You might consider adding receiver tubes to both ends. It would allow you to have a removable carryall. Also I have found it easier & faster to hook up to trailers if I can see the hitch & tongue. Which side of the front end you would hook the trailer to would depend on the direction you need to steer the trailer to keep from running a tire into the tongue.
thanks Im gonna make a carry all next.
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
