Front function
/ Front function #1
coupman35
Northen Ontario
Now a L4060 had B2650
Am thinking of adding a front function on my tractor i have a 7 foot plow that can be angle , so id need function in the front . I look in to it whit the dealer it cost close to 1500.00$ that a bit more then id like to pay so am going to use one of my back remote i have 3 of them .Now is 3/8 hose and fitting a good size .Maybe down the line am going to get a grapple and a tree puller.
/ Front function #2
I ran 3/8"from my rear remotes to the front for my blade or grapple they both will move quite rapidly.
/ Front function
Now just waiting for my L4060 to measure for my back and front hose .Saw a you tub clip looks pretty simple and way cheaper
/ Front function #4
So I have a similar setup however I am having an issue where I am blowing the O Ring on the rear remotes. I hit a chuck of ice and I'm guessing the pressure of the hit blew the ORing.
How can I add a something to relieve the pressure instead of blowing the O ring
/ Front function #5
Cross over relief valve. It will dump excess pressure on one side hydraulic into the opposite side thus avoiding pressure spikes.
Dave M7040
/ Front function
If am going to add a plow in front whit angel . will i need Cross over relief valve to run thiis plow or am ok whit just the function from the back.
/ Front function #7
Won't hurt could save a valve
/ Front function #8
I would also highly recommend a crossover relief valve. I'm generally very conservative while plowing, but while pushing back piles of snow this past winter I hit the relief valve several times.
/ Front function #10
For $10 more I'd go with the 30 gpm even if your tractor is not capable of the 30 gpm an impact or severe push on one corner of the blade could generate quite a spike. Same fittings size and a more realist pressure setting range.
/ Front function #11
I also would recommend one, we sell one on our website.
/ Front function
Well final got my cross over valve but not sure how to install i havent played whit hydraulic much here the installation paper on what side does the hose from the tractor goes
ASSEMBLY & INSTALLATION 1. Connect the hoses from the directional control valve to Ports V1 and V2 of the relief valve. 2. Connect the hoses from the hydraulic cylinder/motor to Ports C1 and C2 of the relief valve. 3. Set the relief valve to approx. 300 PSI over the maximum pressure desired by turning the adjustment screw. 3.1 Turning inward increases pressure, while turning outward decreases pressure. 3.2 One full turn will increase/decrease pressure by approx. 800 PSI.
/ Front function #13
Your lines from the rear remotes go into V! and V2 your cylinder into C1 and C2.
I wouldn't worry to much about setting the relief valve;
you could back it off a couple of turns from the factory setting and start plowing if the blade shifts its self too easily while plowing screw it back in a quarter of a turn till it is working good for your purposes.
/ Front function #14
Uhmm. I didn't realize they were adjustable. I hit the relief valve while carefully pushing some berms this winter - I'll have to take a look at the valve.
/ Front function
Here a few pic of my cross over valve . had to make a small bracket to move it over a bit but now it fit good .Now do i have to blead the hose and my tree puller or just plug it in and play whit the joy stick good to go .
/ Front function
Thanks Dave that was what i was thinking how it was done but better be sure .
2020 Chevrolet Equinox SUV (A61574)
2020 Chevrolet...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
BERKEL 909CT/1 SLICER (A64281)
BERKEL 909CT/1...
2020 CATERPILLAR 299D3 SKID STEER (A64279)
2020 CATERPILLAR...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
