front end loader hydraulic problem
/ front end loader hydraulic problem #1
gemini5362
Ozark Mountains in Arkansas
Montana 4940C
I apologize if this question has been answered before. There are 471 pages of threads and I could not think of a good way to put my question in search. If there is another thread I would apreciate someone directing me to it.
When i try to curl my bucket up it will not curl all the way and it goes very slow. AS soon as i put the control to neutral the bucket curls all the way down and just hangs there loose. I do not see any hydraulic leaks. I went to check my fluid level and when i got the dipstick out there was some air came out under pressure.
/ front end loader hydraulic problem #3
Sounds as if bucket cylinder piston seal is leaking internally.On subject of air pressure in hyd sump sounds as if sump breather is clogged.
/ front end loader hydraulic problem #4
If there are any quick connects between the valve and the bucket cylinders, I would check them out first.
/ front end loader hydraulic problem #5
Given the description, I don't think it would be much else. Most cylinders on stuff that I own eventually creep, but in days to weeks, not seconds.
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
