front end loader hydraulic problem
/ front end loader hydraulic problem #1
gemini5362
Ozark Mountains in Arkansas
Montana 4940C
I apologize if this question has been answered before. There are 471 pages of threads and I could not think of a good way to put my question in search. If there is another thread I would apreciate someone directing me to it.
When i try to curl my bucket up it will not curl all the way and it goes very slow. AS soon as i put the control to neutral the bucket curls all the way down and just hangs there loose. I do not see any hydraulic leaks. I went to check my fluid level and when i got the dipstick out there was some air came out under pressure.
/ front end loader hydraulic problem #3
Sounds as if bucket cylinder piston seal is leaking internally.On subject of air pressure in hyd sump sounds as if sump breather is clogged.
/ front end loader hydraulic problem #4
If there are any quick connects between the valve and the bucket cylinders, I would check them out first.
/ front end loader hydraulic problem #5
Given the description, I don't think it would be much else. Most cylinders on stuff that I own eventually creep, but in days to weeks, not seconds.
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
207272 (A52708)
207272 (A52708)
2 Row 3pt Bedder (A64119)
2 Row 3pt Bedder...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
