front end loader hydraulic problem
   / front end loader hydraulic problem #1
gemini5362
Veteran Member
Ozark Mountains in Arkansas
Montana 4940C
I apologize if this question has been answered before. There are 471 pages of threads and I could not think of a good way to put my question in search. If there is another thread I would apreciate someone directing me to it.
When i try to curl my bucket up it will not curl all the way and it goes very slow. AS soon as i put the control to neutral the bucket curls all the way down and just hangs there loose. I do not see any hydraulic leaks. I went to check my fluid level and when i got the dipstick out there was some air came out under pressure.
   / front end loader hydraulic problem #3
Sounds as if bucket cylinder piston seal is leaking internally.On subject of air pressure in hyd sump sounds as if sump breather is clogged.
   / front end loader hydraulic problem #4
If there are any quick connects between the valve and the bucket cylinders, I would check them out first.
   / front end loader hydraulic problem #5
Given the description, I don't think it would be much else. Most cylinders on stuff that I own eventually creep, but in days to weeks, not seconds.
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
