Front End Loader Hitch Ball & Platform combination
   / Front End Loader Hitch Ball & Platform combination #1
Archdean
Northeast Oklahoma
B7510HST
Total cost Lumber, chain , paint , hitch Ball, misc. $ 40.00
All steel was free from Kubota Dealer I had to cut steel tractor shipping crates with a torch!
All systems interlock and can be used independently!
The total system is mounted using only two Grade 5 bolts in the side panels of the Loader bucket, may change later to two quick disconnect pins!!
I needed a Hitch ball on the front to move boat trailers for mowing, launching etc. Also a safe stable platform on the loader to elevate G/F to clean gutters , trim trees, etc.....(note last slide) Backhoe serves as a ballast box when lifting G/F..... And she approves of this message!!!!!
If any of you would like a complete drawing I would be happy to do one for you!
Dean
Slide Show of combination Hitch Ball & Platform
   / Front End Loader Hitch Ball & Platform combination #2
/forums/images/graemlins/cool.gifDrawings much appreciated. Is a set of plans for the Gutter Cleaner included?
Seriously, yhis is just right for fruit tree pruning, even picking....
Dave in VA
   / Front End Loader Hitch Ball & Platform combination #3
Nice clean design, might work a bit better with a self leveling loader. I also noticed that it was your wife standing on the platform instead her working the loader controls while you tested the platform. /forums/images/graemlins/wink.gif
   / Front End Loader Hitch Ball & Platform combination #4
You should put a 4" toe board aroud the bottom, then you will have a really good safe design.
I left the toe rail off for the express purpose of using the platform for moving firewood , the railing slips up and out of the steel risers , now I am left with flat pallet!!
Thanks for the thought!
Dean
   / Front End Loader Hitch Ball & Platform combination #6
whats needed to open the slide show?
   / Front End Loader Hitch Ball & Platform combination #7
The link tells me "Windows only." Can you post the photos directly to TBN?
Thanks,
Bruce
   / Front End Loader Hitch Ball & Platform combination #8
Album is gone, just an ad for Webshots left and the user was last on here in 2007... Probably not going to happen.
Aaron Z
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Informational Lot - Financing (A55301)
Informational Lot...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
