Front End Loader For F15D
/ Front End Loader For F15D #11
Koyker has a mount kit for a 110 for a F16. I've never had a F15, but I do know that the F155 is entirely different than a F16, but as a newer model that is no surprise. The F18 is entirely different than the F16...so we really can't be sure without some measuring.
Koyker would probably fax you (or their local dealer) the mount dimensions and you can compare them to the F15. Often you can get a very close mount and just modify it slightly to fit. Only do this if you have the capability to do it right.
I a manufacturing Engineer in a machine shop, so this is right up my alley.
Tom
/ Front End Loader For F15D #13
Tom, sounds like you are certainly qualified. Koyker also makes a universal mount kit, that basically comes with the correct pieces you need, but requires cutting and welding. It is a good place to start if they do not have the correct or similar mount that you need. Just remember to check the tire clearance throughout the range of motion of the steering and the pivot of the front axle. Bummer to forget the pivot part and have to take the plasma cutter to newly fabricated mounts! ...not that I have ever had to do that......
Spreader Attachment (A56859)
Spreader...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
