Sep 20, 2010 / front End Fluid #1 M mike65cobra New member Joined Sep 15, 2010 Messages 4 Tractor Kioti CK HST Hi can someone tell me if it is okay to use the trnasmision/hydr fluid in the front end also? Thank-You Mike
Sep 20, 2010 / front End Fluid #2 Highbeam Super Member Joined Feb 9, 2005 Messages 5,321 Location South Puget Sound, WA Tractor Kioti CK30HST On my CK30 you could choose hytrans or gear oil. Since this is a differential with gears, I choose gear oil. OEM fill was hytrans.
Sep 20, 2010 / front End Fluid Thread Starter #3 OP M mike65cobra New member Joined Sep 15, 2010 Messages 4 Tractor Kioti CK HST Sorry to tell you i have a CK35 HST.
Sep 20, 2010 / front End Fluid #4 U ulflyer Bronze Member Joined Apr 13, 2010 Messages 95 Location lexington nc Tractor CK 30H If your ck35 has 4 wheel drive, I'd think gear oil would be what is used.
Sep 20, 2010 / front End Fluid Thread Starter #5 OP M mike65cobra New member Joined Sep 15, 2010 Messages 4 Tractor Kioti CK HST Yes it is 4 wheel drive. Mike
Sep 21, 2010 / front End Fluid #6 ToadHill Elite Member Joined Oct 18, 2005 Messages 2,722 Location Catt county New York Tractor Kioti DK35, Ford 8N, Oliver Cletrac My dealer had me switch from gear oil to Hyd/Trans fluid. If it's good enough for the gears in the rear end I don't know why it's not "OK" for the gears in the front end.
Sep 21, 2010 / front End Fluid Thread Starter #7 OP M mike65cobra New member Joined Sep 15, 2010 Messages 4 Tractor Kioti CK HST Thanks for all your help. Mike
Sep 21, 2010 / front End Fluid #8 BTI Platinum Member Joined Feb 15, 2002 Messages 784 Location Nelsonville, Ohio Tractor CK20S Hydro TLB-LK3054-CK30H We use hydraulic oil. BTI
Sep 25, 2010 / front End Fluid #9 B Bousez Bronze Member Joined Sep 21, 2008 Messages 86 Location Riviere Beaudette, Quebec, Canada Tractor Kioti CK2510 2017 Don't know if it's because of lower temperature here, but my dealer says to use hyd/oil for the front end
