CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,388
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Rear weights are a dime a dozen. Sounds like your neighbor didn't consider the option of adding weight out back.Neighbor had one on his Ford 600, cable lift via pulley to the 3 pt hitch in the back to lift. It worked pretty good down his steep hill, but not so hot going up. And he got stuck a lot! Lifting the blade took a lot of weight off the rear wheels and he could not back out of any kind of grade. Probably would have been somewhat better if he had hydraulics to the front, but I think the underlying issue is the same - raising that much weight out in front of a rear wheel drive tractor = traction loss.
It's not hard, and certainly not a fault of an added front blade.
