front draft rod question
/ front draft rod question #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hello I am having a terrible time getting the front draft rod back in place. It came right off so what am I doing wrong that I can't get it back into the correct hole or the other side in the groove??
/ front draft rod question #2
What model of tractor do you have?
/ front draft rod question #5
Is this the tie rod that goes between the two front wheels or do you have the all wheel steer model?
If front steer only the tie rod goes under the steering arms on each axle and the nuts go on top. I don’t recall exactly how the steering cylinder sits in relation to the tie rods.
Deere has a good parts diagram breakdown on there website
No this is the bracket that hooks to the mower deck and fastens to the frame of the front of the tractor that holds the front of the mower deck up
/ front draft rod question #7
That tractor should have a front mount bracket with a lever arm that goes on left side of the mower. It should have a hook on side of the deck that the bracket slips into and then with cam lever pointing down the front ears on the bracket should hook into slots on the tractor frame mounts. Then rotate the cam lever forward and up to latch in place.
Well I finally got it must of been in a bad bind but finally it went in to place. Thanks for helping me.
/ front draft rod question #9
No problem glad you got it together and thanks for letting us know.
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
