Loader front bucket level indicator
/ front bucket level indicator #1
thepits
canfield ohio
Kubota BX25
I have a Kubota BX25 Just bought it , does anybody know if their is a audible front bucket level indicator ? I'm legally blind and can't tell if front bucket is flat on the ground without getting off the tractor. or if their is a level indicator made for front end loaders.
/ front bucket level indicator #3
Mine has a rod that slides as the bucket curls. I've seen the same type of thing on Kubotas, just not sure which models. It may be something you can order from the parts dept of your local dealer, I'm sure people must snag and or destroy them from time to time. It would also be very simple to build one, just weld on a small piece of pipe and attach a rod that will be pulled/pushed through when the bucket curls. Look at one on the dealers lot to see how it's done.
/ front bucket level indicator #4
No disrepesct intended whatsoever, but if you cannot see if the bucket is on the ground without getting off the tractor, how the heck do you operate the tractor at all? Very curious what you are doing with this machine.
/ front bucket level indicator #5
One could be made by installing limit switch and beeper on loader arm. I do not know of anything commercially available. Another option would be to turn a light on and off on the dash. That way the beeping would not irritate you.
Good luck and have fun with your new tractor! :thumbsup:
/ front bucket level indicator #6
No disrespect intended whatsoever, but if you cannot see if the bucket is on the ground without getting off the tractor, how the heck do you operate the tractor at all? Very curious what you are doing with this machine.
Yeeaah, I'm a bit curious about that myself. If I remove my glasses, I'm legally blind also. I can see enough to get around. I could drive 20-30 mph without running into stuff, I could avoid most obstacles on the road; but I wouldn't be able to spot small stuff like broken glass or other debris in the road before I ran over it. And I'd be much less likely to spot kids about to run into the road; which is why it's not legal for me to drive without prescription eyeglasses. So while you can operate the tractor, there is a higher degree of risk involved.
/ front bucket level indicator #7
You could file notches in the rod at the lower end of the tube that could click against something you could hear. You would have to come up with your own system as to where to put the notches and count the clicks. If it's just a level bucket at ground level that is important, you could put three notches close together with the center one marking level. That way, whether you were going up, or down, the second click would be level.
I have some vision in one eye. I find ways to get things done. I can run the tractor fine just can't see if bucket is level. I try and not let my blindness get the best of me. Have to keep moving on . I just can't see well enough to drive on the roads.
/ front bucket level indicator #9
There is no audible alert. There is a visual indicator, but I still have not figured out how to use it...:confused:
/ front bucket level indicator #10
I congratulate you on your attitude - a man has to know his limitations, but should never let them fence him in! I have a back that is pretty well fused, but I manage to get a lot done despite the pain & lack of mobility, thanks in part to my trusty tractor. Here's what my loader has for a bucket level indicator - should be very simple to knock something similar together for your BX:
Hope it gives you some ideas - good luck!
-Jim
/ front bucket level indicator #11
I've got good eye sight, both eyes and I can't tell if my bucket is level. I need to add a leveling rod.
/ front bucket level indicator #12
Agreed !
The Pits ,,,great to hear you aren't letting this get you down.. Our daughter is 1 or 2 points from being legally blind without her glasses .. See could not see our grandsons lying on the floor without glasses.
OK now ,if you can get a hold of some of the AT&T or Ohio Bell employees they might be able to help you getting info or The Telephone Pioneers of America .
I never helped wired or design items, but we had beeping softballs, beeping cones to play horse shoes. a beeping sound for blind child to shoot a target with a bb gun.
Hope some of this info helps . Like PapaPerk I think a flashing light going to solid color or just a bright light when level would be better than a beeping sound plus in noisy areas you might not be able to hear the beeping sound.
thanks i'll come up with something soon , just trying to figure out how I would set everything up. need some kind of switch. I talked to a guy from ADT I was thinking a door contact would work but he said that they are not weatherproof. i'll keep plugging away and get something to work . sorry to hear about your daughter , i'm legally blind in one eye WITH GLASSES I take them off can't see a thing. been this way for 33 yrs i'm used to it . thanks for the info
/ front bucket level indicator #15
Bakerg, that is just slick! If you put a little jingle bell on the end of the rod, you would hear it when the rod jumps in or out of the the notch. Thanks for the great idea, I think I'll make womething similar.
Bye for now,
Troy
/ front bucket level indicator #16
Why couldn't you just use a simple door contact wired to a relay to control a light or beeper. There has to be two moving parts on the loader that pass close enough to get a magnetic contact to trigger.
You could also rig a mercury switch from an old thermostat but it would stay "on" even past the level point. It would also trigger in your tractor wasn't level.
I was thinking the same thing until I was told that the DOOR CONTACT was not for outdoors and not weatherproof.
/ front bucket level indicator #18
I wouldn't be the least bit concerned at $3 bucks a pop. Heck, throw a plastic enclosure aroud the main body or a little heat shrink. It would take a lot to interfere with the magnet. I would be more concerned with UV than moisture.
Build it, patent it, and we'll all buy it!:laughing:
/ front bucket level indicator #19
I have thinking about making a level indicator using a reverse magnetic switch. I happen to have a switch sitting on my work bench now. The wired switch would be positioned when bucket is level. The reverse actuator would be on a swinging plumb bob bracket. This way you can find level not just on the ground but in any height position.
I have just been thinking about it. I need to make a model and see if it would be practical. Then see if it would work on the bucket. A light or horn, controlled by a relay, would indicate level. Light out or horn off would be out of level. May work, may not.
was thinking of the same thing. I've been looking at some proximity switches and maybe useing a light , I think the horn would drive me crazy . Some people use the rod method but my vision is just not good enough. My son and I was looking at the bucket last night and we are thinking of mounting the proximity switche as low as possible so no brackets would be in the way . i'm sure we will come up with something . thank all of you for your help.
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2016 American Eagle S/A Self Loading Reel Trailer (A60352)
2016 American...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
