Front Bucket Cylinder Leaking
/ Front Bucket Cylinder Leaking #1
Barryh
Veteran Member
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Does anyone have the Specs and or a Source for a the front Hydraulic Bucket tilt Cylinder on the 425 or in my case a 1425 guessing they are the same.. Yesterday noticed the seals are starting to leak on mine. Will call Power Trac if I have to but would rather not pay their inflated prices if I can avoid it . Thanks
/ Front Bucket Cylinder Leaking #2
Ya gotta pay the inflated price unless you have a brilliant hydro shop. I took mine in and they said it would not be possible to create a set.
Sounds about right thanks .. ;)
Thanks I'll check it out ..
/ Front Bucket Cylinder Leaking #7
Did you try getting a seal kit from PT. Pretty cheap.
/ Front Bucket Cylinder Leaking #8
You pretty much have to get the repair kits from PT. O-rings are easy but the wiper seals are harder to find. You could make your own piston but they do not sell the kit without the piston.
Ken
Unused 2021 CID POTSS Skid Steer Quick Attach Conversion Tractor Attachment (A66734)
Unused 2021 CID...
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
