Front Ballast
/ Front Ballast #1
Piperflyer
USA
Kubota3030HST
Helps the front end with the cutter attached
/ Front Ballast #2
Nice job!
Is that a home made brush guard, or did you modify a Kubota guard?
What is that you used for weight? It looks like some big lengths of bar stock. How much weight, do you think?
/ Front Ballast #3
Actually, it looks like square tubing filled with concrete to me.
But looks really good, it does.
/ Front Ballast #4
Yeah...I see the weld seam now. Looks like the square tube was used for a former.
/ Front Ballast #5
That's it? I mean, that's all you have to say? :D
More pics and juke please?
Tell us more about this fine new looking accessory.
I'd like to see how it is attached.
/ Front Ballast
I made it from 1/4" x 6" x 24" sq. stock. It is filled with concrete and comes in at 205 lbs. I can bolt & unbolt it from the tractor (2 bolts) in 10 minutes if need be. I use my floor jack which makes it easy to raise & lower it in position to mount. It really has helped the steering when I have the rotary cutter hooked up. I have about $25.00 invested and a few hrs. of work making it.
/ Front Ballast #7
Nice job & nice tractor too :D
Mount that weight with some good HD bolts, if it comes loose ,
your mower will find it real quick :eek:
Ernie
/ Front Ballast #8
better be some grade 8 3/4" bolts there!
i know around my yard, id snap them off in a hear beet bouncing around my rutted yard....
/ Front Ballast #9
Thank you. I always enjoy pics.
With your skills, I'd darn sure add a 2" receiver type setup to the front of tractor and slide that baby in there, secure with a pin, and be done with it in about 10 seconds. :)
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
Vermeer S450TX (A64126)
Vermeer S450TX...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
