Front Ballast
/ Front Ballast #1
Piperflyer
USA
Kubota3030HST
Helps the front end with the cutter attached
/ Front Ballast #2
Nice job!
Is that a home made brush guard, or did you modify a Kubota guard?
What is that you used for weight? It looks like some big lengths of bar stock. How much weight, do you think?
/ Front Ballast #3
Actually, it looks like square tubing filled with concrete to me.
But looks really good, it does.
/ Front Ballast #4
Yeah...I see the weld seam now. Looks like the square tube was used for a former.
/ Front Ballast #5
That's it? I mean, that's all you have to say? :D
More pics and juke please?
Tell us more about this fine new looking accessory.
I'd like to see how it is attached.
/ Front Ballast
I made it from 1/4" x 6" x 24" sq. stock. It is filled with concrete and comes in at 205 lbs. I can bolt & unbolt it from the tractor (2 bolts) in 10 minutes if need be. I use my floor jack which makes it easy to raise & lower it in position to mount. It really has helped the steering when I have the rotary cutter hooked up. I have about $25.00 invested and a few hrs. of work making it.
/ Front Ballast #7
Nice job & nice tractor too :D
Mount that weight with some good HD bolts, if it comes loose ,
your mower will find it real quick :eek:
Ernie
/ Front Ballast #8
better be some grade 8 3/4" bolts there!
i know around my yard, id snap them off in a hear beet bouncing around my rutted yard....
/ Front Ballast #9
Thank you. I always enjoy pics.
With your skills, I'd darn sure add a 2" receiver type setup to the front of tractor and slide that baby in there, secure with a pin, and be done with it in about 10 seconds. :)
2021 John Deere 4044M (A64126)
2021 John Deere...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2022 EZ-GO ELITE...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
2008 STOUGHTON ZGPVW-535T-SC-AR 53X102 T/A DRY VAN TRAILER (A59914)
2008 STOUGHTON...
