Front Axle Rubber Boot is Torn
/ Front Axle Rubber Boot is Torn #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have a L4740 HST and noticed the rubber boot on a front axle is torn.
1. Is it critical that this boot be replaced?
2. How difficult is it to replace?
Thanks.
/ Front Axle Rubber Boot is Torn #2
/ Front Axle Rubber Boot is Torn #3
Mine's been torn forever (600+ hours) and the replacement tore too. I have decided its easier to replace the socket joint once it wears out. So far it is still tight, I wallop grease onto it each time I grease the loader.
/ Front Axle Rubber Boot is Torn #4
I may wind up doing the same thing as I usually manage to mow some pretty bad stuff regularly.
/ Front Axle Rubber Boot is Torn #5
I don't know about tractors, but I've replaced a few on my Rhino a few times. After putting the boot on, make sure to "burp" it by sticking a flathead screwdriver between shaft and boot to let it equalize pressure. I think in my case (Rhino will do about 40mph), the air expansion from heat caused it to blow out.
/ Front Axle Rubber Boot is Torn #6
The boot on the Rhino is on a CV joint which really has to be replaced or you will wind up buying a new CV joint. The boot on the tractor is on the tie rod.
/ Front Axle Rubber Boot is Torn #7
disregard my post then! :eek:
FLAT BED (A65643)
FLAT BED (A65643)
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
Coleman Minibike (A65579)
Coleman Minibike...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
