Front Axle Rubber Boot is Torn
/ Front Axle Rubber Boot is Torn #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have a L4740 HST and noticed the rubber boot on a front axle is torn.
1. Is it critical that this boot be replaced?
2. How difficult is it to replace?
Thanks.
/ Front Axle Rubber Boot is Torn #2
/ Front Axle Rubber Boot is Torn #3
Mine's been torn forever (600+ hours) and the replacement tore too. I have decided its easier to replace the socket joint once it wears out. So far it is still tight, I wallop grease onto it each time I grease the loader.
/ Front Axle Rubber Boot is Torn #4
I may wind up doing the same thing as I usually manage to mow some pretty bad stuff regularly.
/ Front Axle Rubber Boot is Torn #5
I don't know about tractors, but I've replaced a few on my Rhino a few times. After putting the boot on, make sure to "burp" it by sticking a flathead screwdriver between shaft and boot to let it equalize pressure. I think in my case (Rhino will do about 40mph), the air expansion from heat caused it to blow out.
/ Front Axle Rubber Boot is Torn #6
The boot on the Rhino is on a CV joint which really has to be replaced or you will wind up buying a new CV joint. The boot on the tractor is on the tie rod.
/ Front Axle Rubber Boot is Torn #7
disregard my post then! :eek:
(4) 10-16.5 Tires and Rims (A65640)
(4) 10-16.5 Tires...
Linx EQ7018RS Trailer (A65640)
Linx EQ7018RS...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
John Deere 318 Garden Tractor (A66408)
John Deere 318...
2015 TEXAS PRIDE TRAILER (A65643)
2015 TEXAS PRIDE...
