Front Axle Rubber Boot is Torn
/ Front Axle Rubber Boot is Torn #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have a L4740 HST and noticed the rubber boot on a front axle is torn.
1. Is it critical that this boot be replaced?
2. How difficult is it to replace?
Thanks.
/ Front Axle Rubber Boot is Torn #2
/ Front Axle Rubber Boot is Torn #3
Mine's been torn forever (600+ hours) and the replacement tore too. I have decided its easier to replace the socket joint once it wears out. So far it is still tight, I wallop grease onto it each time I grease the loader.
/ Front Axle Rubber Boot is Torn #4
I may wind up doing the same thing as I usually manage to mow some pretty bad stuff regularly.
/ Front Axle Rubber Boot is Torn #5
I don't know about tractors, but I've replaced a few on my Rhino a few times. After putting the boot on, make sure to "burp" it by sticking a flathead screwdriver between shaft and boot to let it equalize pressure. I think in my case (Rhino will do about 40mph), the air expansion from heat caused it to blow out.
/ Front Axle Rubber Boot is Torn #6
The boot on the Rhino is on a CV joint which really has to be replaced or you will wind up buying a new CV joint. The boot on the tractor is on the tie rod.
/ Front Axle Rubber Boot is Torn #7
disregard my post then! :eek:
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2015 FREIGHTLINER M2 6X4 T/A  24FT FLATBED TRUCK (A59914)
2015 FREIGHTLINER...
2022 EZ-GO ELITE...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
3ft Metal Rooster (A65583)
3ft Metal Rooster...
