Front axle plug on 7510HST
/ Front axle plug on 7510HST #1
jw_NC
I’m trying to check the case fluid on my front axle. There’s a plastic plug on the left side. I’m afraid of forcing it out. I’ve tried to rotate it. It doesn’t seem like it screws in. However, I can’t manage to pull it out and I don’t want to use a tool to leverage it and risk breaking it.
Have people experienced, similar problems or have any suggestions?
Thanks!
/ Front axle plug on 7510HST #3
Try a little penetrating oil, the level check gauge has an o-ring seal and just pulls out. Depending on how cold it is where you keep it, warming it up to room temp would help as well. My B26 was also a bear to get out the first time - it was clear the o-ring never got any lube from the factory. Shoot a little WD at the plug to case interface and work the head of the gauge to help the oil find the o-ring. Pliers may be needed. After getting the gauge out, wipe off any wd off and put some axle oil back on the o-ring before re-installing. Messick's B7510 Parts has a pic of the fluid gauge.
Thanks!!
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
(12) John Deere 1.5bu. seed boxes for JD 7200 planter, Taylor Ridge, IL (A65640)
(12) John Deere...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
