front axle pivot seal
/ front axle pivot seal #1
fih25
central PA
Kubota BX 1500,Cub Cadet LTX 1042
My BX 1500 has a leak at one of the front axle pivot seals. Searched the forums on this and not sure replacing it is something I want to tackle. I checked with the dealer where I bought it and they quoted a price of $400-$500 for replacing both front seals( I asked for an estimate for both since if one is leaking the other can't be far behind). I thought that was a little much, what do you all think? Oh and that price was me delivering and picking up the tractor. I had already switched the fluid from super udt to 80-90 gear oil in the winter when it first started to leak. It stopped back then, but the other day I noticed a couple drops on the garage floor after I had been using the tractor with the 4wd engaged. It's not leaking bad at this point, but unfortunately leaks never get better. Any ideas or thoughts would be appreciated.
2009 Ford F-250 4x4 Crew Cab Pickup Truck (A61568)
2009 Ford F-250...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
832651 (A61165)
832651 (A61165)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
