Front Axle Fluid Level on BX1500
/ Front Axle Fluid Level on BX1500 #1
BXAK
ALASKA
Kubota BX1500D
To get an accurate reading do you want to thread the dipstick all the way into the axle or just poke it in?
(There is a big difference in the two readings)
Thank you
/ Front Axle Fluid Level on BX1500 #2
@BXAK
Unfortunately an educated opinion is no more than a coin toss.
I would likely contact your local Kubota service department and see what they say, but that may not be the correct answer.
How about draining and measuring the existing fluid and comparing to the spec capacity? You don't always get the spec capacity back in when doing a fluid change, but refilling with the spec amount should put you in the ballpark.
/ Front Axle Fluid Level on BX1500 #3
@BXAK
It is just a gear box so I don't think it is that big of a deal. I would thread the plug in to measure .
