Traction Front axcel leaking
/ Front axcel leaking #1
woodmasters
DK 40 Se
I was moving some dirt today and noticed gear oil on the left front rim. I removed wheel and noticed that gear oil was coming out behind the wheel hub and 8 bolt gear case cover. Does anyone have a parts brakedown for the axcel assembly or has anyone else had this problem? Thanks Woodmasters.
Up date on leaking front axle seal. Seems the outer bearing piled up and took out seal,axle shaft and gear cover. Not sure what took out bearing but parts are on order. Thanks to all who helped. PS
/ Front axcel leaking #5
Just curious, how many hours are showing on this tractor?
There is just under 1100 hours and there was around 900 on when i purchased it used.
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2016 KENWORTH T800 TRI-AXLE (A65643)
2016 KENWORTH T800...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
Rolling Cart (A65640)
2024 CATERPILLAR CP56R PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
