Traction Front axcel leaking
/ Front axcel leaking #1
woodmasters
DK 40 Se
I was moving some dirt today and noticed gear oil on the left front rim. I removed wheel and noticed that gear oil was coming out behind the wheel hub and 8 bolt gear case cover. Does anyone have a parts brakedown for the axcel assembly or has anyone else had this problem? Thanks Woodmasters.
Up date on leaking front axle seal. Seems the outer bearing piled up and took out seal,axle shaft and gear cover. Not sure what took out bearing but parts are on order. Thanks to all who helped. PS
/ Front axcel leaking #5
Just curious, how many hours are showing on this tractor?
There is just under 1100 hours and there was around 900 on when i purchased it used.
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
8ft 3in Teakwood Live Edge Slab Table (A65583)
8ft 3in Teakwood...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
