Traction Front axcel leaking
/ Front axcel leaking #1
woodmasters
DK 40 Se
I was moving some dirt today and noticed gear oil on the left front rim. I removed wheel and noticed that gear oil was coming out behind the wheel hub and 8 bolt gear case cover. Does anyone have a parts brakedown for the axcel assembly or has anyone else had this problem? Thanks Woodmasters.
Up date on leaking front axle seal. Seems the outer bearing piled up and took out seal,axle shaft and gear cover. Not sure what took out bearing but parts are on order. Thanks to all who helped. PS
/ Front axcel leaking #5
Just curious, how many hours are showing on this tractor?
There is just under 1100 hours and there was around 900 on when i purchased it used.
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2013 Chevrolet Step Van/ Command Center (A64556)
2013 Chevrolet...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
