From vertical to horizontal - proposed engine swap!?
   / From vertical to horizontal - proposed engine swap!? #1
NormL
Platinum Member
Manitoba, Canada
Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
At the outset of my mini-backhoe build I knew that at some point the tired old 18hp Briggs would have to go. I had hoped to get at least ten or more hours of digging in first. That was not to be as outlined in the thread I had going during the build "It's time, either get started or..." So I'm starting a new one for the purpose of gleaning the great advice TBNers have for those of us who tend to operate "by the seat of our pants" in projects like I am facing. Like my title suggests, the engine coming out is a vertical shaft model. It is original with the tractor, a mid-eighties Sears Craftsman. That means there is not enough clearance between the end of the output shaft where the drive pulley for the mower deck it used to have is, and the ground, to direct-mount a hydraulic pump. The belt drive I tried instead has failed miserably. The belt slips the moment I try digging. I have a thirteen hp horizontal shaft engine I can mount in that space and this where I am hoping anyone who has done this will step up with helpful hints, tips and "encouragement?"..
   / From vertical to horizontal - proposed engine swap!? #2
A hydraulic pump should not care if its mounted vertically or horizontally as long as it can get suction from reservoir.... There are housings to adapt pump to motor and use love joy connector from motor shaft to pump shaft....
   / From vertical to horizontal - proposed engine swap!? #3
Norm
Something to check is the bearings style on your pump . Some pumps are designed to handle side load on the shaft from belts and others are not.
on belt drive use a double pulley system to increase power transfer. Belts should be matched length for doing this though.
   / From vertical to horizontal - proposed engine swap!? #4
Norm
Belts can be bought in matched sets.
Thank you for those tips! At present, the pump is mounted vertically like the engine and driven by belt from a five inch B pulley to a ten inch B pulley. It has been suggested that switching to a double belt setup would help and I'm sure it would. The issues involved make that impractical. There is only so much "wiggle room" under the tractor and at my age my "wiggle" is more like "wobble"!! The pump functions well till the belt slips under load. As for mounting the pump directly, I will shop locally at Princess Auto for the mounting gear. If they don't have it, I'm not averse to fabricating my own.
Norm
You are right about side load and my pump will not allow it. My present mount takes that into account so it is in good shape for mounting directly. I'll have to open it up and change the rotation back to factory before I do that!! The biggest problem I see to double belt the present setup is the way the pulley on the engine is mounted to the output shaft. It looks like it was on there from the factory and intended to be permanently attached. Keep in mind this is a garden tractor that came with a mower deck and the pulley I have been using to run the pump was the drive pulley to that deck.
And if going that route was an option I would make sure I was using a matched pair!! My walk-behind snow blower is a good example of the importance of double belts being matched. I bought a set that supposedly matched; they did not and I had to toss them and buy another set. Grrr....
   / From vertical to horizontal - proposed engine swap!? #8
If belts are slipping you need bigger pulleys or more belts, or even both. Small pulleys dont have much contact area to transfer power. You can swap engines days on end. I swapped engines and the belt still slips...
   / From vertical to horizontal - proposed engine swap!? #9
I would use gear pulleys and belt.
The only belt after the engine swap will be the one to the trans axle which is not a problem. The engine in there now is vertically oriented and the one going in is horizontally oriented which leaves plenty of room to mount the pump directly onto the output shaft. The biggest issues will be redirecting the drive belt to the trans axle from a below the engine platform pulley to an above the platform pulley. The most likely scenario is to cut an opening into the platform once I am sure of exactly where the replacement engine will stand and then reposition the various pulleys along the way between engine and trans axle. This includes the clutch pulleys and at least one additional idler to align the belt in relation with the new opening.
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
cummins generator (A56857)
cummins generator...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
405 (A52706)
405 (A52706)
