Freedom tractor?
/ Freedom tractor? #1
Jeepfarm
Just a John Deere D100 at the moment
Hey everyone. I have been looking for a tractor and I came across one that I can not find any info on. It looks to be a 80's vintage Freedom FT-254 tractor. It is yellow and has a logo of a horse with tires instead of legs. I can not find any info on the web for Freedom tractors. I see that Foton has a FT254 but can find nothing on a Freedom. It has a XINXING 385 engine and is 4WD. If anyone has any info on these tractors I would love to hear about it.
/ Freedom tractor?
/ Freedom tractor? #3
If you can find nothing on the brand it may well be an orphan with no repair parts available. It may be a wonderful and capable tractor but when it breaks you may find yourself unable to fix it. I have a grey market Mitsubishi tractor. Yes, it's a name brand but this model was never sold in this country. Consequently finding parts can be interesting.
/ Freedom tractor? #4
Were I looking at an unusual tractor brand, first thing I would do is try to find parts online. No parts. No purchase.
/ Freedom tractor? #6
/ Freedom tractor? #7
it's interesting that if the tractor is made in China, that it would be allowed to be called Freedom!. Freedom in China??.. maybe it's made somewhere else!..
/ Freedom tractor? #8
Foton has been using FT-254 on models, Chinese tractors gets the name the customers want, they have no sense for building a brand name like other manufacturers.
/ Freedom tractor?
It is likely a re-badged popular Chinese brand Like Jinma, or a Korean Kioti or Daedong. It will be in these lists somewhere but under a different name. A GOOD pic of the engine nameplate would be helpful.
/ Freedom tractor?
Yes this was my fear. That is why I was trying to find out if anyone had heard of it. I was trying to see if it was just a rebranded tractor that you could get parts for under the other name.
/ Freedom tractor? #13
List of tractor manufacturers - Wikipedia
Chinese tractors | Tractor & Construction Plant Wiki | FANDOM powered by Wikia
Little effort turned up an engine parts manual.
Parts Manual - Xinxing Y385T
most likely. and ther probably used off the shelf parts available in China, although almost everything is made in china now, because it's a lot cheaper. the problem would be what parts does this use, and it could be a combination of parts used!..
/ Freedom tractor? #15
A true oxymoron. :thumbsup: :laughing:
/ Freedom tractor?
Good. Is there a block casting logo such as a diamond with "JD" inside it, or any other casting ID's?
I am unsure of any casting numbers. It does have this on the steering wheel.75220726_2828109587221904_1529172884688207872_n.jpg
/ Freedom tractor?
The logo on the steering wheel leads me to believe it may be a Jinma, if the wheel is original.
/ Freedom tractor?
OK so mystery solved! I was searching through a list of tractors that Jinmar makes/made for other companies and stumbled on Iron Horse tractors. They are the same color yellow and have the same horse logo. Not sure if the Freedom name on the side was put on there after the fact. Thank you for all the help.
/ Freedom tractor? #20
I translated the Chinese writing on the name plate... It translates into English as,
STAY AWAY!!
SR
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2018 MACK LR633 6X4 TA GARBAGE TRUCK (A66091)
2018 MACK LR633...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2018 CASE 750M WT CRAWLER DOZER (A65056)
2018 CASE 750M WT...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
