Frame Weld on 1983 Kubota
   / Frame Weld on 1983 Kubota #1
jacm
I looked at a L245 last night with a FEL at a used tractor dealer. He didn't know the history beyond the previous owner who he thought had owned it about 5-6 years. There was a weld on the left side of the frame about 6 inches behind the front axle. Is this something that happens commonly and should be ok or should I pass on this one? Thanks for any help.
   / Frame Weld on 1983 Kubota #2
If the price is right and everything else looks
good get it.
If the weld either cracks or doesn't suit u,
grind and reweld or plate it on backside and
grind front smooth and repaint.
   / Frame Weld on 1983 Kubota #3
My B7100Hst with Fel Has had most of the welds on the support stucture redone as well as those holding the bucket on. Seems to still work ok.
Egon
   / Frame Weld on 1983 Kubota #4
Could have been welded do to a stress crack or a bad factory weld.It may be worth taking a closer second glance of L245 also a test spin.
It's on the tractor frame.
   / Frame Weld on 1983 Kubota #7
Is it a surface weld or is it welded on both side of the frame. Is ther a corresponding weld on the other side of the tractor. Could the tractor have started to crack in half. If the cracks looks deep I would pass....
excavator trenching bucket- one bucket per lot (A56435)
excavator...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
