Frame Weld on 1983 Kubota
   / Frame Weld on 1983 Kubota #1
jacm
I looked at a L245 last night with a FEL at a used tractor dealer. He didn't know the history beyond the previous owner who he thought had owned it about 5-6 years. There was a weld on the left side of the frame about 6 inches behind the front axle. Is this something that happens commonly and should be ok or should I pass on this one? Thanks for any help.
   / Frame Weld on 1983 Kubota #2
If the price is right and everything else looks
good get it.
If the weld either cracks or doesn't suit u,
grind and reweld or plate it on backside and
grind front smooth and repaint.
   / Frame Weld on 1983 Kubota #3
My B7100Hst with Fel Has had most of the welds on the support stucture redone as well as those holding the bucket on. Seems to still work ok.
Egon
   / Frame Weld on 1983 Kubota #4
Could have been welded do to a stress crack or a bad factory weld.It may be worth taking a closer second glance of L245 also a test spin.
It's on the tractor frame.
   / Frame Weld on 1983 Kubota #7
Is it a surface weld or is it welded on both side of the frame. Is ther a corresponding weld on the other side of the tractor. Could the tractor have started to crack in half. If the cracks looks deep I would pass....
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
202476 (A54757)
202476 (A54757)
2018 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A55973)
2018 Ford F-350...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2015 Peterbilt 320 Garbage Truck (A55973)
2015 Peterbilt 320...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
