Frame size between Yanmar models
/ Frame size between Yanmar models #1
abwehrly42
East TN
Yanmar YM1500
I recently built a frame to adapt a loader to my YM1500. It attaches to the front bumper, the frame in front of the bellhousing, four tapped holes in the cast transmission housing, and four holes at the bottom of the rear axle.
If I wanted to upgrade to a larger Yanmar are there any that would have the same frame dimensions? Looking at a couple 2210s because of their shuttle shift.
/ Frame size between Yanmar models #2
From my quick chk. the 1500 Front axle is the only model listed for the Front Axle Housing FAH-4190. The next larger models goes to the YM1700-2000 models.
The Spindle changes for the YM2500,3000,3110,3810 models is all I can find.
/ Frame size between Yanmar models #3
From what Carey said all those 2000 models are the same frame and axle. The 2000,2001,2002, 2020,2010,2210 etc. Not sure if you followed that or knew.
/ Frame size between Yanmar models #4
Nothing would have the same frame dimensions. The 1500 is larger than the YM1300 & smaller than the YM2000
/ Frame size between Yanmar models #5
I’m wondering if my YM 240 will accept a loader from a YM 226 loader is the YM 800.I figured if the frame is the same it will work.Any advice would help greatly.Thank you
/ Frame size between Yanmar models #6
I know of the Gray Market YM models and farme sizes. The YM240 is like the YM2000. The frame size is one level below the YM2500 or JD850. If you compare the loader for a JD850/950 and the YM800 fits a smaller machine, then by deduction it should fit, otherwise should it be equal to a JD850/905 or larger like the JD1050, you are out of luck.
/ Frame size between Yanmar models #7
I have a used ym240 loader for sale Email me if interested
LOOK! (A63111)
LOOK! (A63111)
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
Case IH 800 (A64127)
