Found this during oil filter change
   / Found this during oil filter change #1
Chargerdude70
North Branch, Michigan
LS G3038H
Anyone know what this white item is? Its in the exact position in picture as when I took the filter off. At first I thought it was part of the old filter that had broken off. When inspected, the filter was intact.
   / Found this during oil filter change #2
It looks like a piece of paper blocking the hole the oil goes through.
thank you for the reply...no..its a piece of plastic...shaped like a cone..what you see in the picture is the back side of it...or flat side....
   / Found this during oil filter change #4
Looks like the paper seal from a quart bottle of oil. Why would you put it there? Seems to me it would block the oil flow.
i didnt put it there...it was there when i took the old filter off...and this is the first 50hr service filter change to boot
   / Found this during oil filter change #6
Back when I did my first hydro change and filter clean (which was way past due) I found where the dealer had punched a hole in one end of the micro-screen filter so they could use one that fits in a cartridge instead of the OEM filter which has a bolt through it. Made me mad, but it worked so I let it go.
   / Found this during oil filter change #7
I would be sending that picture to LS. That filter had to be working in bypass all the time and the oil never got filtered. I would start all over with the 50 hr service and ask them to pay for the 1st one. If you haven't dropped the oil maybe just put a new filter on and run for 6 to 8 hrs then do the full 50hr service.
   / Found this during oil filter change #8
Yes, being cone shaped I'd say it was a shipping plug on it that should have been removed before a filter was installed.
   / Found this during oil filter change #9
It looks like some kind of factory plug to keep debris out during engine assembly. If so, it's a poor idea. They should use a cap plug that also covers the external thread so it must be removed before the filter will go on.
This was my thought and worry.
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
Globel Industrial 44" Water Cooled Fan, 24" Electric Pedestal Fan (A59076)
Globel Industrial...
2021 CTS T/A End Dump Trailer (A55973)
2021 CTS T/A End...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CATBKTSSL_78 (A55787)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
