Found this during oil filter change
   / Found this during oil filter change #1
Chargerdude70
North Branch, Michigan
LS G3038H
Anyone know what this white item is? Its in the exact position in picture as when I took the filter off. At first I thought it was part of the old filter that had broken off. When inspected, the filter was intact.
   / Found this during oil filter change #2
It looks like a piece of paper blocking the hole the oil goes through.
thank you for the reply...no..its a piece of plastic...shaped like a cone..what you see in the picture is the back side of it...or flat side....
   / Found this during oil filter change #4
Looks like the paper seal from a quart bottle of oil. Why would you put it there? Seems to me it would block the oil flow.
i didnt put it there...it was there when i took the old filter off...and this is the first 50hr service filter change to boot
   / Found this during oil filter change #6
Back when I did my first hydro change and filter clean (which was way past due) I found where the dealer had punched a hole in one end of the micro-screen filter so they could use one that fits in a cartridge instead of the OEM filter which has a bolt through it. Made me mad, but it worked so I let it go.
   / Found this during oil filter change #7
I would be sending that picture to LS. That filter had to be working in bypass all the time and the oil never got filtered. I would start all over with the 50 hr service and ask them to pay for the 1st one. If you haven't dropped the oil maybe just put a new filter on and run for 6 to 8 hrs then do the full 50hr service.
   / Found this during oil filter change #8
Yes, being cone shaped I'd say it was a shipping plug on it that should have been removed before a filter was installed.
   / Found this during oil filter change #9
It looks like some kind of factory plug to keep debris out during engine assembly. If so, it's a poor idea. They should use a cap plug that also covers the external thread so it must be removed before the filter will go on.
This was my thought and worry.
2020 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2020 Komatsu...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A57454)
New/Unused 72inch...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
