Found odd tool under tractor seat.
/ Found odd tool under tractor seat. #1
jimmy1
Tara, Ontario
Mahindra Emax 25s cab
I found what at first seemed to be the strangest tool under my tractor seat. I was blowing snow and had to get off the tractor to move a vehicle, so I disengeged the pto and put the tractor in neutral but the engine stopped when I got off the seat. It would not start when I got back on so I started looking around for what might be the problem. It turned out to be a build up snow and some ice around the saftey shut off connected to the seat. Anyway when I was looking around I discovered something lodged in a recessed area and when I removed it I discovered what I think is a surgical forceps. You know the thing that looks like a scissors with a clamping mechanism at the handle to hold it closed while it is attached to something. So I wounder what is that doing under there? My best guess is that I had rear work lights added to the tractor included in the purchase. They are installed about 2/3 up the roll bar and when the mechanics fisched the wires through they would probably clamp this forceps on to the wires as to hold them in place. Like an extra hand.
You never know what you can use to get thing done.
Jim
/ Found odd tool under tractor seat. #2
Jim, it sounds like you found a hemostat and you're probably right about where it came from. I use to use one when I done a lot of trout fishing. Makes getting those small hooks out a breeze. Pretty handy little tool.
/ Found odd tool under tractor seat. #3
Sounds like a roach clip to me. :)
/ Found odd tool under tractor seat. #4
Post a pic. A lot of people have acquired hemostat-like surgical clamps and use them as tools. Usually they get worn out beyond being able to be used in the OR and then the hospital staff acquire them then they make their way out into the general public. Post a pic and I'll let you know for sure.
/ Found odd tool under tractor seat. #6
Billy,
Exactly what I was thinking. Beats the heck out of alligator clips I've heard. I use them in soldering all the time. Make good heat sinks as well.
David B
/ Found odd tool under tractor seat. #7
We all seem to be thinking the same. Probably took a break, lit one up and dropped the hemo's. Was too stoned to find them. Do the lights work?:D :D :D
/ Found odd tool under tractor seat. #8
They're not lights. He put in two flashing strobes and a glitter ball in the middle.........Probably fell off the back fender and said to **** with the Hemo's.....
/ Found odd tool under tractor seat. #9
The last time I was in the ER for stiches the gave me the hemostats, tweezers and sisors. They can't be reuse and you pay for them.
/ Found odd tool under tractor seat. #10
You mean, "Do the lights work, duuude?" :D
/ Found odd tool under tractor seat. #11
Save the hemostats for fish hook removing. I keep a pair in my ice bucket all winter. Reach down the fish's mouth, clamp onto the bend in the hook, push down, turn 90 degrees and lift out.;)
/ Found odd tool under tractor seat. #12
They aren't black lights are they?
Sorry Chuck, My equipment does not include the camera to attach a pic. It does fit the hemostat description though.This one is 6" with a slight curve on the end.
My problem now is to I take them back or put in the top drawer of my tool box? ;) Tool box for sure!
Black lights,strobe lights, this is going waaay back in time. Amazing what a little tool can do.:D
Jim
/ Found odd tool under tractor seat. #14
Do they look like this?
6.5" curved tip hemostat:
BamaRob, that is exactly what they look like.
Jim
/ Found odd tool under tractor seat. #16
BamaRob -- I never saw a tool that looked like a red X. At least that's what shows up here. :)
Wait, now that I've posted this, the pic is here. Yep, those are a real good imitation of a hemostat.
/ Found odd tool under tractor seat. #17
You could post that find in Soundguys "Using wrong tool for job" thread. But I agree, they do come in handy.
2004 Brenner DOT 407 Insulated T/A Chemical Tanker Trailer (A64194)
2004 Brenner DOT...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2025 Grapple Rake Mini Excavator Attachment (A64553)
2025 Grapple Rake...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
