Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #441
Hey All,
So, I did removed the muffler on my 186F due to it being restrictive at the outlet at the head. I welded up a pipe and stuck it on there. Runs better now but its deafening. I need some sort of a muffler.
Anyone ever replace a muffler with something other than OEM?
Just order something off eBay or go to tractor supply. A small muffler off like a international cub or some small zt lawnmower should work.
   / Forum for air cooled diesel engines and clones #442
Thats what I was thinking but then again thinking restriction. Just looking for ideas....
   / Forum for air cooled diesel engines and clones #443
Hello too all !
I am new here and from Sweden.
I have a Chines 186f with electric starter
and a 230/400V 3-phase generator. It has a remote
start that has faild. (yes, new battery in sender)
I found a new used sender/reciver but it not works as suppose to.
First I would be happy to find a electrical drawing for my motor/generator, and a source where to buy a new remote that fits my generator.
The two recivers looks different inside, I will try to put up some
pics. It is the reciver with 4 relays inline that worked fine until it just died....
I have to be back with pictures later.
I hope that you understand my old school English !��
   / Forum for air cooled diesel engines and clones #444
Here is pictures of the recivers and the generator ! 20190221_133539.jpg20190305_185152.jpg
   / Forum for air cooled diesel engines and clones #446
Hey Guys,
I've got a Titan 7500 D w/ the 186. Had a couple of questions that you might be able to help with:
1: Any suggestions on how to firmly pin down the engine and it's variants like A, AF, FE, etc.
2: The gen head failed after about 125 hours. (Exciter coil burned up.) The output shaft taper on the motor is a bit of an oddball and i can't seem to find a compatible gen head. (Most everything here is either J609 A -or- J609 B.) This one might be more accurately described as Chinese " Electrical Taper " ? Any leads on a 6KW gen head ?
Thanks
   / Forum for air cooled diesel engines and clones #447
Guys, I'm trying to replace the governor oil seal on my 186F. I took the speed control off to access it. There is a pin that looks like it needs to be popped out. The pin though is not budging. I've been hitting it with a hammer and punch but I do not want to hit it so hard I damage the fork. Any ideas/suggestions?... I am taking this off correctly right?
Thanks
Randy B
Looks like 1 pin secures it.
Support the arm as you tap the pin out to prevent damage.
   / Forum for air cooled diesel engines and clones #449
Thanks, I looked up the pin # and it is a tapered pin so that helps a lot. I'll get back to it in another day or too.
   / Forum for air cooled diesel engines and clones #450
While I ponder how to get my stuck taper pin out... Someone school me on the "Start of Delivery" method for timing a diesel.
Thanks,
Randy
Deere 350G LC (A53317)
2016 Subaru Forester 2.5i Premium Sport Utility 4D W/ 201K Miles (A59225)
2016 Subaru...
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
2018 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP6JFD27162, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2018 Ford F-150...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
Pressure Washer Trailer (A56857)
Pressure Washer...
