Forth Project ( USA box Blade)
/ Forth Project ( USA box Blade) #1
Mansker
Edwardsville--Illinois
NH TC 33D / ford NNA
I took and old Danuser Blade, Says it was made in Fulton Mo. I welded !/4" plate to the sides, cut rectangular holes in a 4" square tube and welded it to the side plates. I purchased the scarifying blades from TSC. I turned down some 3/4" steel to 5/8" and drilled the pin holes in the ends for the clips. Added some holders for the pins to slip into and reinforced the top and bottom where the blades are. I made a 2" receiver with ball and welded it on for towing.
Painted it up for the good ol US of A and here it is ready to dig.
Here it is with the blades up for gravel and dirt spreading
/ Forth Project ( USA box Blade) #4
I think that is the first box blade I have seen that pivots like a rear blade. /forums/images/graemlins/shocked.gif
Nice paint too... /forums/images/graemlins/smile.gif Almost too pretty to want to use.
Great job!
/ Forth Project ( USA box Blade) #5
Do you keep your digicam in the Pelican case on the bench to protect it while in the shop? The blade looks good! I wonder why no box blades come with tilt built in?
/ Forth Project ( USA box Blade) #6
wow nice job, how did ya cut the holes plasma cutter or mill them with an endmill?
/ Forth Project ( USA box Blade) #8
Nice looking box blade. If we were to hook that one up would we have to salute it before we could use it? /forums/images/graemlins/wink.gif Almost too handsome to drag in the dirt.
/ Forth Project ( USA box Blade) #9
Well done. Good lookin' blade. It does, however, appear that the teeth on the scarifiers are upside down.....BobG in VA
Here it is hooked on and ready to go, I Saluted it, hopped on and bladed the driveway! /forums/images/graemlins/grin.gif It worked very well for Goverment Issue /forums/images/graemlins/smile.gif
/ Forth Project ( USA box Blade) #11
Nice job and you have a great looking shop. How big is it? I've got 900 square feet and mine is fine for me, but cold this time of year.
Turfman:
My shop is only 24'x24' way too small! You can't have too big of a shop just like you can't have too big of a pole barn. My house furnace went out several years ago and I took my old furnace and fixed it up again and built an insulated little room on the side of my shop and put the Furnace in it, now I have heat and water, doesn't get any better than that( unless someone else paid for the Propane.)
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Forth Project ( USA box Blade) #13
Great job, Mansker! I did something similar. Not near as high quality, though. How does yours handle? Is there enough weight? The one I made is only 48" (much smaller tractor), and I built in a weight tray using the 4" tube as the front support, the blade as the back. Just made walls all around to contain some cement blocks.
