Forks mounted on toothbar teeth.
   / Forks mounted on toothbar teeth. #1
wawajake
Canada
Kubota BX2660 , Kubota RTV X1100C
Thanks to many of the posts here I saw advantages to having a set of forks for my BX2660.
I wanted something I could move pallets around (if I ever get around to storing my firewood on pallet boxes) but I also wanted flexibility of a single fork that I could use as spear to get under brush tree roots and pull them up . I also wondered if I could use some 6 inch channel iron that was here when I bought the property. So thought maybe I could make something that would fit the channel around the bucket teeth of my Markham toothbar.
So with my limited welding skills (Lincoln AC Arc welder ) and scrap pieces of angle iron so I would not need to spend hours cutting metal with my carpenter circular saw with cutoff blade.
Here is what I came up with. The teeth of bucket slip into the channel like a foot going into a slipper, and then the turnbuckles tighten it in place. Forks extend under bucket so that toothbar and bucket spread forces if ever an issue.
Lessons learned...they were a little sloppy unless turnbuckle is very very tight , so I ground the underside of that angle iron at a 45 roughly same width as tooth and that allowed tooth to be held better in place but still could be better. I did add a 45 inch of small angle to join the two forks under the bucket to hold them even better. And extra holes are there if I choose to have the forks moved to the two inner bucket teeth (so forks 20 apart ) and of course one fork alone can work in the middle tooth.
I also ended up making a general purpose box for carrying with some plywood , to triple the amount of wood I can carry in the bucket and can lift it the 6 ft high I need to get it near back door of house. I can take box and forks off by just undoing turnbuckles and tilting bucket to back out of it and leave it at my equipment staging area . All and all I am pleased with outcome. Total cost with free scrap steel was only the wood and orange paint and turnbuckles so $90 .
Open to suggestions if slight modifications would even further improve .
   / Forks mounted on toothbar teeth. #2
Very neat idea, how much weight can you carry with it?
   / Forks mounted on toothbar teeth. #3
nice job and kudos on thinking outside the box
i've got something else to thank you for - i've been meaning to put some teeth on my FEL (homebuilt) and seeing yours reminded me - i've got about a doze wedges from scrap steel about the size of log splitting wedges -
got so much junk, forgot what i've got -
good job on the forklift attachment
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
UNUSED FUTURE...
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
TANK MANIFOLD (A58216)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
