Forks...Forks...Forks..
/ Forks...Forks...Forks.. #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Hey all after searching and reading and more searching and reading, i would like to purchase some forks. But I am leaning towards the Titan forks as it wont break the budget. I see most 42-48" tines are out of stock.. Any one else know where to purchase? Thanks.
/ Forks...Forks...Forks.. #2
Check Messicks, they have a big sale on some odds-and-ends and I saw some SSQH type forks mentioned. Land Pride clamp-ons too.
Well found a used pair of 4”x 42” forks on marketplace and purchased a titan frame. I’m ready to go. One of the forks is a bit sticky on the frame, so just got to use it or grind a bit so I can move it a bit easier.
/ Forks...Forks...Forks.. #4
We just got the 42 Titan forks a few months back. Very happy with them and love how they are set up for the bale spears. Will be buying the spears soon to install on the same frame.
/ Forks...Forks...Forks.. #6
SSQA forks will let your loader pick up heavier loads because the weight is closer to the pivots.
I use a set of 42" titan SSQA forks to move IBC tote cages loaded with firewood. They weigh close to the loader's capacity. If I don't slide the forks in fully and leave just a few inches, the loader can't curl the weight.
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
(2) 8' panels, (1) 80" X 24" SIDE PANEL (A64280)
(2) 8' panels, (1)...
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
(20)PIECE UNUSED SDLANCH HIGH END 2M RATCHET STRAP (A64280)
(20)PIECE UNUSED...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
