Forks...Forks...Forks..
/ Forks...Forks...Forks.. #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Hey all after searching and reading and more searching and reading, i would like to purchase some forks. But I am leaning towards the Titan forks as it wont break the budget. I see most 42-48" tines are out of stock.. Any one else know where to purchase? Thanks.
/ Forks...Forks...Forks.. #2
Check Messicks, they have a big sale on some odds-and-ends and I saw some SSQH type forks mentioned. Land Pride clamp-ons too.
Well found a used pair of 4”x 42” forks on marketplace and purchased a titan frame. I’m ready to go. One of the forks is a bit sticky on the frame, so just got to use it or grind a bit so I can move it a bit easier.
/ Forks...Forks...Forks.. #4
We just got the 42 Titan forks a few months back. Very happy with them and love how they are set up for the bale spears. Will be buying the spears soon to install on the same frame.
/ Forks...Forks...Forks.. #6
SSQA forks will let your loader pick up heavier loads because the weight is closer to the pivots.
I use a set of 42" titan SSQA forks to move IBC tote cages loaded with firewood. They weigh close to the loader's capacity. If I don't slide the forks in fully and leave just a few inches, the loader can't curl the weight.
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
Caterpillar D6R Dozer Service Manuals (A63117)
Caterpillar D6R...
(1) UNUSED 12" RUBBER TRACK (A64280)
(1) UNUSED 12"...
