Forklift
/ Forklift #1
BSims66173
Alabama
Mahindra 4110 4x4
Just wanted to post a pic of the forklift attachment I made for my loader. The forks are just made from 4" channel and I expect them to give some. The frame is made of 4" channel and 3/8" plate. It took a good bit of tourch work and welding but I finished it today. Tried it out today and was suprised at how well it did. Moved some 3' x 20' metal roofing that had been covered with kool seal. Each sheet weighs between 50 to 80 pounds. I moved between 5 to 10 pieces at a time and nothing broke. Anymore than that and it would lift the rear of the tractor. I am real pleased with how they perform and I built them for less than $75.00. Not bad for an ole country boy from Alabama.
/ Forklift
Didn't get the pic attached on the first post. Sorry. Here is a side view.
/ Forklift
One more sort of from the rear. Also during the process of building the forks, I made my bucket a quick detach so it would be a little easier to change from bucket to forks and back. You can see the pin on this side close to the bottom on the fork.
/ Forklift #4
If you box the back side of the forks with either 1/4 or 3/8 flat stock, you'll increase the strength considerably, and eliminate a lot of flex.
/ Forklift #5
Very nice job! Considering to buy a new set of forks for a skidsteer is about $400 sounds like u did ok!! /w3tcompact/icons/smile.gif
/ Forklift #6
Wow Really Nice! Can you start an order form,
Gerald, Franz needs one too heehee
/ Forklift #7
Nice job. Here is a picture of one I made for my 3 pt hitch. I made it out of 3/4 inch steel and it gives a bit two but will hold 4 railroad ties okay.
/ Forklift #8
You have any pictures to post of the quick detach system you made???
I have a bucket, pallet forks an snow plow FEL mounted. The bucket an forks
are no big problem but the snow plow takes a crew if it's not perfectly level...
/ Forklift #9
Very good idea, nice need job. how much can you lift without rearing up, the forks look quite sturdy?
/ Forklift
Gunfighter, I don't have any pics but will take some and post. Basically what I did was cut the mounting brackets off the bucket and welded a spacer plate between them and a 1" piece of cold roll across the top. Then I made hooks and welded them to the bucket and the forklift. Welded some plates on the bottom for the pins to line up with and that was it. I 'll get some pics tomorrow and you will see what i mean.
/ Forklift
Bubenburg, Not sure how much I can lift without rearing up but I know without any implement on back maybe only around 500 pounds or so. Picked up 8 full crossties today with nothing on back of the tractor and it was about all it could handlewithout lifting the rear tires. good thing I have 4x4. the forks are pretty sturdy but will flex if picking something up on the very end of them.
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
150 Bushel Side Dump (A64127)
150 Bushel Side...
