Fork extensions
/ Fork extensions #1
kubota2630
A very good friend of mine made me fork extensions. I did a post a short time ago and got some good feedback. I wanted to use them to move my snowmobiles around. I have a Kubota B2630 with pallet forks. I found that I don't have enough lift capacity to lift anything heavier then the snowmobile in the picture. I can't lift any higher then in the picture. I was hoping to lift the snowmobile into my pickup. I know the lift capacity is drastically reduced the further forward the balance point is. Is there anyway for me to increase my lift capacity? (bypass valve pressure) I just need a slight increase.
Thanks
/ Fork extensions #2
Don't tell the safety cops but raise your RPM's up a little and don't get caught
/ Fork extensions
Thanks. I did but it only helped slightly.
/ Fork extensions #4
Sell the Yamaha and buy a lighter snowmobile??? Just kidding - I have a similar set-up, I have a B2410 and it will lift my Ski Doo Rev 600, but it won't lift it high enough to get it in my truck. It will take it out of the truck, because the curl is strong enough to clear the front. I ended up building a nice ramp set up to get the sled into my truck. Wish I had a better answer for you.
/ Fork extensions
Thanks everyone. I guess it won't work. I'll have to use my homemade ramps.
/ Fork extensions #7
putt_putt_green said:
Get the engine of the snowmobile closer to the tractor.
QUOTE]
Can it lift the snowmobile if is crosswise on the forks? If it can and you have the lift height available, could you put it on a sling and come in from the side of the truck? Clearances might be an issue but the closer you get the weight to the pivot points, the better off you will be.
/ Fork extensions
I'm sure I could lift it higher from the side but would not be able to lift it over the side of my truck. I think if I had some one to lift slightly on the bumper of the snowmobile I may get it high enough lifting it as shown in the picture. I've got all summer to play around with it.
/ Fork extensions #9
My B3300 won't lift mine either. Incluiding a little 440 Fan, and a new lightwieght ski doo summit (e-tec 600). Niether are beasts. The forks & extensions probably wiegh 250 combined. If I built something custom to replace both just for this, from Aluminum it may work, but would be a spendy experiment. Need one of you w/ a TIG to do that for us!
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
2019 John Deere 4044M (A62177)
2019 John Deere...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
