Ford
rasaiton
Ford 1700
Ford 1700 transmission is stuck in 4 range, is there a easy trick to free it
It should be similar to my 1900, which also gets stuck occasionally. On the top cover there are some bolts I believe 2, they hold down the ball bearings which act as a detent, loosen those up all the way with just a thread or two remaining this should relieve the pressure and let it shift. Keep in mind if you take the bolts all the way out and shift the lever you'll be chasing detent balls, ask me how I know, lol.
Good luck hope that made sense.
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2017 Ford F-550...
