Ford
rasaiton
Ford 1700
Ford 1700 transmission is stuck in 4 range, is there a easy trick to free it
It should be similar to my 1900, which also gets stuck occasionally. On the top cover there are some bolts I believe 2, they hold down the ball bearings which act as a detent, loosen those up all the way with just a thread or two remaining this should relieve the pressure and let it shift. Keep in mind if you take the bolts all the way out and shift the lever you'll be chasing detent balls, ask me how I know, lol.
Good luck hope that made sense.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
Lone Star dump trailer (A55973)
Lone Star dump...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
